Hitch Drop Question on a Lifted Jeep
Old Mar 28, 2017 | 02:11 PM
Ozzmann's Avatar
Default Hitch Drop Question on a Lifted Jeep
This Thursday I am getting a 4 inch lift installed on my 2016 JK with 35 inch tires. I have a small 4 x 8 trailer now and use a 4 inch drop. Does anyone know how to calculate or what drop I will need with these new modifications? Thanks for the help.
Old Mar 28, 2017 | 02:32 PM
JordanHaskin's Avatar
Hard to guess because you really need to have both halves set up the way it's going to be, and within reach of each other. You could guess how much higher the Jeep will be or just wait. Here's a good link on how to measure. https://www.etrailer.com/faq-ballmount.aspx
Old Mar 28, 2017 | 04:36 PM
nthinuf's Avatar
Hmm.
4" drop now.
Frame is going up 4" due to lift.
32" tire (?) to 35" tire. 3" height difference, or 1.5" increase for the frame.
4 + 4 + 1.5 = ?
Or just wait until the lift and tires are on, back up to trailer, and measure...
Old Mar 28, 2017 | 05:29 PM
karls10jk's Avatar
Wait and measure. I've been fine with a 2" drop for quite a while then bumped to 35's and needed a larger drop.
Just FYI- a 4" kit is a similar lie to tire size, you won't see every inch they're selling you. 35's will measure up short as well.
Old Mar 28, 2017 | 09:36 PM
sea bass's Avatar
I would just install a 5.5" lift on the trailer so you can still use your 4" drop hitch.
Old Mar 29, 2017 | 11:21 AM
Ajkaz's Avatar
Originally Posted by nthinuf
Hmm.
4" drop now.
4 + 4 + 1.5 = ?
This^^^^
Wait until you are completely done and measure. I run an adjustable hitch receiver and use the 9.5" drop setting. My pop up is lifted from the factory but where my hitch mount connects to the Jeep bumper is elevated. Trailer & Jeep handle well together and feel safe. 2 door with a 1500lb loaded pop up.
