Hmm... is this normal?
Old Jun 29, 2009 | 05:34 PM
smuhhh's Avatar
Default Hmm... is this normal?
I was just washing my jeep and I noticed that there seemed to be more room between the frame and the tire on the drivers side in the rear as compared to the passanger side. I know that lifting will shift the axles, but I also have the drop trac bar bracket. I have a 2.5" TF lift by the way. Anyways, as I measuring and looking at that, I noticed that my passenger side rear is lower than my drivers.
All in all, my tires are offset to the drivers side by about 1/2 inch in the back and my passenger side is sitting 3/4 inch lower than the drivers side. Is this from the gas tank? that really seems like a lot of drop to me... like should I be able to notice it from looking at it? kinda bugs me now. I hope this isn't a bigger problem, or me needing a new coil.
Any advice would be awsome. Thanks!
Old Jun 29, 2009 | 06:32 PM
mkjeep's Avatar
WOl suggests getting ADJ rear sway bar links and adj your low side abit higher to get rid of the gangsta lean.
Old Jun 29, 2009 | 07:21 PM
wheezer's Avatar
I had the same rear wheel offset problem when I installed my 2.5 TF lift. I installed an adjustable track bar and it did the trick.
I'm not sure about the lean.
Old Jun 29, 2009 | 10:11 PM
blazer4949's Avatar
The lean is "normal" with JK's. As stated, using adjustable swaybar links is one way to help
the lean, I use JKS links. And....carry the heavy stuff on the drivers side, extra battery, tools,
rock collection, etc.
Old Jun 30, 2009 | 06:17 AM
smuhhh's Avatar
Could I use a coil spacer instead? I have a set kicking around.
Old Jun 30, 2009 | 06:20 AM
TeraFlex's Avatar
Sponsoring Manufacturer
Yes you can.
