holy cow, death wobble disaster
Ok, I had Les Schwab put a 3" Fabtech lift on. I noticed a Death Wobble at around 30-40mph. I hadnt had a chance to get it in to have them look at it. Today I noticed a change. I could not go more than 12mph and it would kick in bad. I got it back to the Rig and got under there again and the front track bar mount is broke all the way off! I am out here 35 miles of dirt and another 20+ to town and 120mi to Les Schwab. Im tring to locate a welder up here that can weld it back on so I can get it to town. Has anyone had this problem with the front? Will a heavier mount fix it or is it a different problem?
yep its becoming a common acurance. do a quick search on here and you will find several people with the same problem, mostly caused by the relocation bracket used for trackbar on most lifts.
price we pay for being the guinea pigs for the jk'
Is this a first?
Scary
I had seen an incident on a rear and the lift company shot him an upgraded mount with apologies. If you look at that bracket, its weak and only 3 little welds, its not even welded on the inside, anyway Les Schwab is getting ahold of Fabtech to see if they have an upgraded bracket, keep your fingers crossed.
JK-Forum Founder
I'm glad to hear you're okay and did get into an accident. If you can afford it, I would recommend ditching the relocation bracket, have your track bar axle mount rewelded on with a support gusset if possible and then get a new adjustable front track bar. Relocation brackets on the axle mounts act like a lever and will most likely pry the thing off again like bending a paper clip back and forth over and over again.
Not alone
You are not the only one that has faced this problem. After the rear bracket sheared off and I had it fixed by reinforcing it and welding it back I had problems with the front trackbar bracket. It happened on a Friday evening in the boondocks. I had a 60 mile ride at less than 20 mph to get back to camp and a welder. I have a skyjacker 4" lift. I called them and they said they had never heard about the problem with the front bracket. They offered to send me a rear bracket brace if I paid for shipping. It seems that these companies didn't really put their test vehicles through any really rough paces or they would have experienced these problems. Skyjacker said they went to Moab. We weren't on the trails an hour before we had our first breakdown. They must be gentler than us crazy guys!:sad:
