Hood laches
Old Mar 2, 2011 | 06:20 PM
Mcflurry301's Avatar
Default Hood laches
So today while drive I have come to notice that my hood is bouncing around at high way speeds and when passing 18 wheelers. I am travling across the country so I dont have time or place to get tighter laches. Has anybody had any problem with their hood popping up or breaking?
Old Mar 2, 2011 | 06:22 PM
racin444's Avatar
Daystar hood latches are the way to go! Cheap solution and permanent fix!
Never heard or had any problems with the hood popping up though.
OzzyPotter's Avatar
It is called hood flutter and you can search on it. I had it and took the one nut holding the hood spring off and then the spring off. This completely removed the hood flutter. The spring holds up the hood slightly and road wind will get under it from time to time when the gust is right. This cause the hood to flutter. The safety latch should theoretically keep it down if the side latches both broke simultaneously. It is more of a sense of doom than probably a real threat. Remove the spring and see if it goes away. It takes a small wrench or hex nut driver if I recall. A small crescent wrench could suffice.
Old Mar 2, 2011 | 06:24 PM
ZombJep's Avatar
x2
ronjenx's Avatar
I have not seen any reports of hoods flying open from latch and safety catch failure.
There are lots of threads on easy ways to eliminate the hood flutter.
Biggy's Avatar
Tons of threads on this.Their is no danger but if it bothers you put some plastic tie-wraps around the latch. Their are a few solutions out there.Time to use the search function
Old Mar 2, 2011 | 06:30 PM
Cdyspeed's Avatar
i did this the other day and worked like a charm
Old Mar 2, 2011 | 06:34 PM
j2d013's Avatar
Daystar Hood latches all the way......
Old Mar 3, 2011 | 12:47 AM
Mark Doiron's Avatar
Originally Posted by Biggy
... put some plastic tie-wraps around the latch. ...
There are various solutions out there. Some folks have had luck removing the spring previously described--others report hood dance under extremely severe conditions. Two years ago the plains states were having very high winds. It was during the trip out to Easter Jeep Safari for hundreds of JKs, and that's when everyone found out whether or not their chosen solution to hood dance worked--most did not! Anyway, a couple eleven inch zip ties will stop it cold. Small disadvantage is that after a period of time they may break. Keep a spare or two in the glove box ...
Old Mar 3, 2011 | 01:13 AM
gijeep's Avatar
just buy the 12 dollar daystar latches and be done....
