Hood Lift, has anybody tried these.....
just wondering if these work well and eliminate the hood flutter. Driving through the mountains last night at 85 mph with the wind blowing and it's pretty sketchy how much it lifts!
https://www.jk-forum.com/forums/modified-jk-tech-2/daystar-hood-wrangler-replacement-hood-latches-33058/
https://www.jk-forum.com/forums/showthread.php?t=33058
How do you hit 85MPH in the mountains (downhill?). I was happy to maintain the speed limit in the Rockies.
As to the issue, I just removed my spring and haven't seen happen since.
Another solution is to find a couple black zip ties and run them around the OEM rubber that stretches. Just tighten them enough to keep the extra stretch out nd cut off the excess. Lots of us down south have been running like this forever now...$0.10 fix or less.
I was having similar issues on the highway during windy days. I went with this write-up (see link below) to add some support to the existing seal between the hood and the grill...it worked out great and it cost less than $15 for both the tubing and adhesive.
https://www.jk-forum.com/forums/jk-write-ups-39/hood-lift-fix-7124/
