Horns!
Old Sep 16, 2010 | 07:34 PM
matt852's Avatar
Originally Posted by PainKiller
the freeway blaster is a pretty good one, I was at pep boys last week and saw that one The fuse might blow if you hook up two of them without a relay because if I remember right the stock horn is low voltage besides anything is better than that stock duck call
Good to hear I was kinda nervous when I first hooked it up because it was a lot bigger then the stock one so I wasn't sure if it would blow the fuse. But then the box said stock drop in capable. The have one that functions at 400 hz and the other at 500hz. I think I bought the one that is 400hz because it said big rig sound on the box
Old Sep 16, 2010 | 09:07 PM
steelzeppelin's Avatar
Just got my buddies emergency horns for 50 bucks. I can't wait to get them going
Old Sep 16, 2010 | 09:31 PM
Red Dog's Avatar
I am going to Google that Hella horn and put it on my “to do” list.
Old Sep 17, 2010 | 06:15 AM
bkw's Avatar
bkw
I had the PIAA's on my last truck and I did not use the relay. I spliced the piggybacked off the stock wiring (+,-) and they worked fine.
Depending on where you decide to mount them, you can either use flex steel brackets ($.79 @ Home Depot) or 3M double sided molding tape since these dont weigh much.
On my JK, I have the Hella's - one mounted behind the headlight (stock location) and the other one down by the frame.
As for mud / water protection, I've submersed the lower one and it still works.
Old Sep 17, 2010 | 07:09 AM
RevyJKU08's Avatar
Just curious, How has your new horn system handled the deep mud/water crossings mounted in the lower portion of your grill? Any issues?
all done
[IMG][/IMG]
[IMG][/IMG]
