Horsepower on the cheap
I have a 2010 jk love the look hate the baby motor in the hood. Is there any turbo or super charger out there that is not going to brake the bank ??? Or is there anything other than aor intake i can do to inprove my hp?
Superchargers are available for the 3.8...there's a couple guys running them here on the forums. They can tell you more about cost and headache more than I can.
I owned a 3.8, although it was a 2-door. It was slow, but it was a good motor and got the job done, on-road and off-road.
Forced induction that is not done right will only lead to the potential for leaning out the engine and causing detonation. Running an engine to lean will melt the pistons. Even if you have the correct AFR (Air Fuel Ratio) you still run the risk of running to much boost and blowing a head gasket.
The best way to add forced induction is to lower the compression ratio and add in boost. It will make way more power than running the little amount of boost that you can (safely) with a normally aspirated engine.
