How bad would 35s be?
Old Nov 27, 2010 | 05:04 AM
JPop's Avatar
With 3.21s and 35s you are going to burn up the clutch pretty quick but it can be done. 6th gear is out of the question, and 5th gear becomes your OD gear. Shouldn't be the big fuel mileage hit that you would see on an automatic, and you'll likely be about 20% better than the auto.
Old Nov 27, 2010 | 05:51 AM
byorchard's Avatar
I just put 35s (315/70R17) Duratracs on my 6sp 2dr with 3.21s. I've only been driving it for a little over a week. My long term gas mileage (computer) was 20-21 (combined country and small city driving - no highway, no rush hour). It's been 18.5 since I reset it the day I put on the tires but colder weather plays a part in that too. 6th gear is not "gone" but is only good for flat or slight downhill at 50+ mph. I find that I run in 4th more often, less in 5th (i.e. 35-40 mph in 4th instead of 5th). Taking off in 1st is noticeably different so I'm sure it's a little harder on the clutch. I will probably regear in the future but feel like I can run as is for quite awhile.
Bear in mind that I have a 2 dr. Your experience will undoubtedly be different in an Unlimited with the extra weight and longer wheelbase.
Old Nov 27, 2010 | 06:31 AM
JPop's Avatar
The aero drag at 60+ mph is where 6th is going to be tough if not impossible. It makes up a huge percentage of the power you need to keep a JK rolling. The weight and rolling resistance drag increases with velocity in a linear fashion while aero drag increases exponentially. By the time you reach 70mph more than 80% of the power made is being used to cope with aero drag. At 50mph it's only about 70%.
Old Nov 27, 2010 | 07:09 AM
byorchard's Avatar
Ahh... that makes sense. I almost never even hit 60. I guess it all comes down to the type of driving you do. I know I would like 4.88s better!
Old Nov 27, 2010 | 07:10 AM
RubiKing's Avatar
Get 35's you will deeply regret getting 33's the moment you see a jeep on 35's. I regreted getting my 33's about two weeks after I got them.
Old Nov 27, 2010 | 07:50 AM
roadking54's Avatar
Originally Posted by asuperhero
christ....12.5? im still stock and i get about 17. 12.5 is a bigger hit than i thought it would be. ordering my tires and lift on friday i've been so excited that im constantly looking at all my gear everyday.
i guess i could take the 5mpg hit... i live in seattle, and there's TONS of hills all over the place. please tell me your power on hills isn't THAT bad...i already know 6th is gonna be gone. and regearing will take a helluva long time.
Seattle hills are doable....although I had 35's / auto / 3.73's before I regeared. Get yourself a Superchip. With my superchip tune and O/D off on 3.73's w/ 35's, I had more power and get-up-and-go then I did stock with 32's.
Old Nov 27, 2010 | 08:02 AM
JPop's Avatar
OD off gets you 40% more rpm at cruise speeds which more than makes up for less than a 10% increase in tire size. Off road is quite different story.
Old Nov 27, 2010 | 08:41 AM
aggie sig's Avatar
Originally Posted by Harbourone
If you're in Houston id go see lunatic customs. I believe they have a deal going for gears installed for 900$. That's parts and labor. That's a good deal.
good deal yes, but add that to a 8 hour round trip drive to Lunatic in DALLAS, and 2 tanks of gas and it becomes not so sweet of a deal...
Just because 2 guys are in TX doesn't mean they are close it's not like your pissant northeaster states J?K
Old Nov 27, 2010 | 11:49 AM
Olean NY Jeeper's Avatar
My clutch is fine. I have not smelled burned clutch on a vehicle of mine since I was 16.
Old Nov 27, 2010 | 12:27 PM
JPop's Avatar
You don't need to smell burning clutch to be using it up. At idle the vehicle is ready to roll at 6mph and some level of clutch control needs to be applied until you reach that speed. It also 50% more mph than what the standard recommendation for 35s with a manual transmission, meaning that with the appropriate gear set less clutch control needs executed.
