How bad would it be......
Old Mar 22, 2009 | 02:49 PM
scbesse's Avatar
Default How bad would it be......
To use 3" full Traction 2 door Coils on a 4 door??? They are HD Coils but not sure if it will work thanks guys
Old Mar 22, 2009 | 03:03 PM
Robar's Avatar
They will fit, but I'm not sure if Full Traction uses different spring rates for the 2 or 4 door versions. At worst you wouldn't get a full 3" of lift.
Old Mar 22, 2009 | 03:45 PM
08{GA}RUBICON's Avatar
Call Full Traction and see if there is a different spring rate. Then you will know and knowing is half the battle!
Old Mar 22, 2009 | 05:45 PM
scbesse's Avatar
I just emailed them to see. I figured at worst I would get less that 3". that would be fine too, thanks guys
