How to center rear track bar?
Old Dec 13, 2010 | 03:55 PM
Hellbound13's Avatar
Default How to center rear track bar?
Installed Currie rear track bar, what do I need to measure from to make sure it's centered?
Old Dec 13, 2010 | 05:33 PM
Pluke the 2's Avatar
Is it adjustable and do you have a lift kit installed?
I think I have seen like 100 threads started by "Hellbound" all of them having to do with changing out suspension parts. I didn't mean to make this sound rude, just trying to figure out the situation
But I measure from the middle of my tires to the middle of the frame on each side.
As a starting point, when I put on my suspension, I used my sway bars as the starting point to know how centered the rear axle was...
Old Dec 13, 2010 | 05:43 PM
No lift, I have been replacing all the worn stock parts from when I had DW with better aftermarket parts.
I have the Currie in the front and wanted the same in the rear.
Its a nice track bar that has a poly bushing on one end and a Johnny joint on the other.
When I removed the stock bar I measured from bolt sleeve to bolt sleeve as best I could then matched the Currie to that.
Now I just want to make sure its centered on the Jeep and need to know best place to measure from.
