How did you attach your Harbor Freight winch plate to the frame?
Who has the Harbor Freight winch plate? How did you attach it to the frame? I have the winch plate, and a brand new XRC8 winch in the garage and I'm needing to get it installed!
There are quite a few threads on this. You have to use the search feature.
I didn't find anything that showed how to attach the Harbor Freight winch plate. I'm hoping somebody can help.
I am not sure if the plates are exactly the same. I have a Champion winch and winch plate. Very generic, I cut the bumper to fit around the plate. I mounted it right to the top of the frame rails. I did have to drill one hole on each side. It fit tight to the top of the rails. There were three bolts throught the top layer of the frame rail on each side. very secure. the plate ws the same width as the frame rails. I have since changed bumpers. I hope this helps. good luck
http://my.project-jk.com/data/500/me...b_2007_007.jpg |
I drilled new holes in the plate and used 4 grade 8 u-bolts running around the frame rails. It was pretty low on the hassle scale, and it's solid.
edit- I did have to trim off the rear "lip" to keep it from interfering with the painted grill. |
Originally Posted by capt scotty
(Post 1211932)
I have the same "universal mount" (actually two) sitting in my shed. I could not figure it out either so I mounted the winch to the bumper instead of the frame.
Originally Posted by bone
(Post 1212065)
Did you run your bolts all the way to the bottom side of the frame rails, or did you just put a nut under the top of the rail and bolt it there? Did you drill all the way through the frame rail, top and bottom? How long were the bolts?
Originally Posted by TxCop07
(Post 1212288)
hell if you come to the beach run on sat i will give you one
