How to do a hard reset of ecu?
How do you do a hard reset of the ecu so the automatic trans relearns new shift points?
Subscribed...
put the fuel pump fuse for 15min and that should reset the ecu
Disconnect the battery negative terminal for a time. Not sure how long, but 30 minutes should cover it. To guarantee a reset, leave it over night.
Originally Posted by ronjenx
(Post 1266171)
Originally Posted by 08jk4door
(Post 1266187)
the fuel pump fuse is the same thing but they said about 15-20min should do it if you do the pump fuse you are not turning the power to every thing else in the jeep. both work or should work
I didn't know about the fuel pump fuse supplying power to the TCM. I usually advocate the battery negative terminal because it works for a host of computer problems and is a single item to remember. |
(Post 1266193)
You posted while I was composing mine.
will try thanks guys. i'll let u know if it works.
