How to do a hard reset of ecu?
the fuel pump fuse is the same thing but they said about 15-20min should do it if you do the pump fuse you are not turning the power to every thing else in the jeep. both work or should work
I didn't know about the fuel pump fuse supplying power to the TCM. I usually advocate the battery negative terminal because it works for a host of computer problems and is a single item to remember.
almost all dodge /jeep chrysler cars /truck and jeep made in the late 90's to present usually the fuel pump fuse will re set the ecu that is what i have been told but the neg. battery will do the same thing
