How do I get the front shocks off?
I have tried for over an hour to get that top nut off the front shock post. I can move it with an adjustable wrench. There isn't enough room for a socket (dumb design). There's barely enough room for a wrench. What am I doing wrong? I bought a ratcheting wrench and it doesn't work... Too big to fit.
I think my problem is the adjustable wrench. If I can get a grip on it, it turns without much difficulty. Stock X shocks, replacing with Rubicon takeoffs. I think I'll go buy a dedicated wrench of the proper size. The backs were cake. 30min for both.
16mm adjustable box wrench is the ticket. Make sure you're using the correct side for loosening (there are arrows on mine). Also vice grips on the bottom side of the mount so you don't just keep spinning it around and around.
Lowe's is the only place I could find that has a 16mm by it self for sale. (Tried HD, and about 3 auto parts stores) Hope this helps save you some time.
When I took my stockers off it was like I could only loosen 1/8 of a turn at a time, just really hard to get that top wrench in a good spot, took me a good hour on one side. New ones went on in 30 sec as the nut wasn't rusty.
