How do I get my drag off?
Im installing a synergy dragljnk flip kit, but cant get the stock bjoint off the pitman arm
Any suggestions would be much appreciated
This:
11-3/4" Ball Joint Separator
It may cause a little damage to the rubber sleeve around it but I beat the hell out of mine, tried using a puller and so on for hrs. This took 10 sec.
This: 11-3/4" Ball Joint Separator It may cause a little damage to the rubber sleeve around it but I beat the hell out of mine, tried using a puller and so on for hrs. This took 10 sec.
Took me about 50 whacks with a hammer before it finally came off.... I even tried using a long bar coming down from the engine compartment to strike the top of the pin downward (with the nut slightly threaded on) Almost gave up and then it finally came apart.
