How do I grease JKS Jspec Front lower control arms?
Once installed, there is no way to get a grease gun on the zerk.
Are you guys unbolting the axle end every time you grease your front zerk?
How often do you grease it?
Has anyone cut or drilled a hole in the front LCA mount to make room to grease it? I would think that would weaken the mount considerably.
Or, do I have them installed wrong, and I should of pointed them down, which makes NO SENSE at all to me. ROCKS.
Thanks for any input!
I had the same problem with my teraflex front lower joint. During instal I noticed there was no way I was going to be able to grease them so I put them on the bottom. I wasn't too worried because the zerk fitting was actually pointed about 45 degrees to the rear, and if I did happen to knock one off, they are easy and cheep to replace. 5 for $10 at checkers
