How do I remove my dash?
Looking to install a light switch between my 2 air vents. How do I remove the top part of my dash. (the little part in the middle) Also will that give me enough acess to install a switch?
I slid something like a credit card in, and lift back part, then the whole thing slides to the front. From there, the radio remocal should be easy. Otherwise, if you remove the airvent bezel. Can you not then get in there? (Press on outer ring, and turn, it can only go one way, then pull out.)
Sent from my iPad using JK-Forum
