How do I reset my ESP / Traction control lights?
Old Aug 2, 2009 | 08:49 AM
ShawnJ's Avatar
Default How do I reset my ESP / Traction control lights?
Just finished my lift and re-centered my steering wheel on Friday. I Didn't get the wheel perfectly straight the first time and when I was test driving, the ESP / Traction control lights came on and remain on.
How do I rest the lights?
Old Aug 2, 2009 | 09:42 AM
ShawnJ's Avatar
Anyone . . . ?????
Old Aug 2, 2009 | 09:46 AM
STUPIDFACE's Avatar
If im not mistaken, mine just went off when i got everything back centered.
corey d
lv jk's Avatar
***erator
I think you just turn the car off for awhile, mabey it was drive it once corrected?
WOW I am a lot of help! Anyway I never actualy had to do anything once the problem was fixed the lights turned off.
Old Aug 2, 2009 | 09:53 AM
dfe's Avatar
dfe
Dealership, or if you have Superchips Flashpaq you can use that too.
Old Aug 2, 2009 | 09:56 AM
mkjeep's Avatar
Undo the neg on your bat terminal and let it sit for 20 min. It should reset. Or other people have driven around for awhile and it goes off on it's own. First way gets rid of it quick.
Old Aug 2, 2009 | 10:03 AM
0311sgt's Avatar
Go to your local Advance Auto shop. they can read clear codes free of charge. If the lights do not go off it may be an ALIGNMENT CODE..... that is why you should have it read somewhere. Maybe nothing, maybe something. But i do know from personal experiance if the alignment is not correct it will throw a code and light up all the pretty ESP dash lights
2007 JK Unlimited 6 Speed 4.10 Gears
3 Inch BDS Lift
35x12.5x16 Yokohama Geolander AT/S
16x8 Cragar Soft 8 Black Steel Wheels
Custom front Winch Bumper from RoundStar OffRoad
Mopar Offroad Rear Bumper
Oilpan/Tranny skid Plate by Skid Row
JKS Quicker Disconnects
Skyjacker Brake line extenders
Skyjacker Adj Rear track bar
High Clearance Adj Front Lower Control Arms by RocKrawler
RocKrawler Front Lower Control Arm Mounting Bracket/Skid Plates
Warrior Products Rear Safari Doors
Plenty of ROCKRASH
Old Aug 2, 2009 | 10:26 AM
ShawnJ's Avatar
Default Thank You!
Thanks . . . . will try to disconnect battey terminal first!
I plan on doing a alignment myself tomorrow when I can get it into a bay @ work.
Very happy with the lift and tire combination.
I will post some picks later!
Old Aug 2, 2009 | 10:46 AM
bigbluejk's Avatar
x2. I know 1st hand both work.
Old Aug 2, 2009 | 11:42 AM
ShawnJ's Avatar
Default Didn't work
I disconnected the Neg terminal on my battery and left it of for 20 min. = ESP Traction control lights still on. Then tried again for 30 min = lights are still on. I will go to have Advance Auto read the code w/ an ODB II and see what happens.
I was under the assumption that when you dissconnect power it would clear the code (in this case lights) until I drive it and the system detects an alignment problem then re-sends the code. Is this not true.
