How do my alignment specs look?
Old Jul 26, 2011 | 07:19 PM
Scott08X's Avatar
Default How do my alignment specs look?
I had to go to Sears for a new battery today and they did a free alignment check. I just had it aligned about a week ago after getting front and rear 60s and 37s put on. It drives good just curious how these numbers look. I will be installing adjustable control arms this week(stock right now) of that will help. Thanks!!
Old Jul 27, 2011 | 08:32 AM
Scott08X's Avatar
Old Jul 28, 2011 | 06:24 AM
snl7271's Avatar
Looks like they just did a static alignment check beings there is no caster readings. Which means they only used alignment heads on just the front wheels. Also there are no numbers showing what you actual readings were.
Old Jul 28, 2011 | 07:09 AM
mkjeep's Avatar
Yeah, all that's on that sheet is the stock specs for toe and camber, no castor, and no readouts of what you are at right now at all.
Edit, looks like they gave some kind of camber readout on it, no toe though or max at the toe tolerence?
Or just some kind of readout that your at the max spec on toe and camber on one side and the other, doesn't look like normal readout to me.
Hell , bring it somewhere else, that readout is funky.
Old Jul 28, 2011 | 07:17 AM
unatarpok's Avatar
I got one of those the other day too. To me it seems like Sears was trying to sell me a $80 alignment.
