How do you "check" gear ratios
Old Apr 15, 2011 | 06:58 PM
allenw's Avatar
Default How do you "check" gear ratios
I have had a few people post and tell me that my jeep is acting strange because it might have different ratio in the used d30 I just had installed. How do I "check" to make sure it is 3.73 like the original?
Old Apr 15, 2011 | 07:13 PM
Mad-Hatter's Avatar
pop the cover off and it should be stamped on the ring gear.
Old Apr 15, 2011 | 07:26 PM
ronjenx's Avatar
Chock both right side tires.
Put the transmission in neutral, transfer case in 2wd.
Jack both left side tires off the ground, support with jack stands.
Put a chalk mark on each drive shaft, lined up together.
Spin the front tire (by hand) 2 revolutions. Count the front drive shaft turns.
Spin the rear tire (by hand) 2 revolutions. Count the drive shaft turns.
They should have turned the same number of turns, and the chalk marks should have stopped in the same locations.
The number of drive shaft turns will also be the gear ratio.
Old Apr 16, 2011 | 08:38 AM
allenw's Avatar
Holy cow!! You are right. 3.75 times around on the back and over 4 on the front. Why would the mechanic not know this. You are the man ronjenx!
