How do you fix a wallowed track bar hole ?
Old Oct 3, 2010 | 07:15 AM
Bwest99svt's Avatar
Default How do you fix a wallowed track bar hole ?
Ive been having a lot of death wobble issues so I ordered a new track bar. When I took the stock one off I noticed that both holes were wallowed a bit and the bolt does move some. What is the best way to fix this problem ?
Old Oct 3, 2010 | 07:17 AM
Widowmaker's Avatar
Weld washers on over the wallowed hole
Old Oct 3, 2010 | 07:20 AM
Bwest99svt's Avatar
Thats what I've read so far. I didn't know if there was an easier way since I don't own a welder. I wasn't sure if there was a bracket you could buy instead
Old Oct 3, 2010 | 07:30 AM
Serg5000's Avatar
Using a washer is maybe the best way to fix this. I would suggest a set of washers that are as thick as the bracket itself. This is a fix I am going to do before it needs it. Not sure what to say about you not having a welder. Maybe a friend could help you out. Good luck man.
Old Oct 3, 2010 | 08:28 AM
knightrohulk's Avatar
What causes the hole to get "wallowed" out like that? Is this common on JK's?
Old Oct 3, 2010 | 09:53 AM
Robar's Avatar
If the track bar bolts are not torqued correctly it allows the bar to slip and wallow out the holes.
Old Oct 3, 2010 | 10:11 AM
Bwest99svt's Avatar
Does anyone know what size washers I need ?
Old Oct 4, 2010 | 04:40 PM
storch's Avatar
Is the slop in the hole a major cause of stearing wheel shimmy or death woble when hitting bumps in the road?
Old Oct 5, 2010 | 02:53 AM
Bwest99svt's Avatar
I hope thats the problem. My jeep does fine until I hit rail road tracks then i have full on death wobble and have to completely stop.
Old Oct 5, 2010 | 01:27 PM
Bwest99svt's Avatar
Stupid question
Can too much tire pressure cause death wobble ?
