How do you tighten a stripped nut/bolt?
Old Jan 30, 2012 | 05:29 PM
defierro's Avatar
Default How do you tighten a stripped nut/bolt?
So I installed my after-market front bumper today. The bumper had 3 bolts coming out on each side of the mounts, and one nut for you to put the bolt through (I hope you understand). Anyway, I was tightening all the nuts and bolts. On one of the 2 bolts, I started screwing in sideways. Stupid me tried to tighten it with a wrench and ended up stripping the bolt inside of the bumper. All other 7 all perfect though. How shall I put on the bolt? I was thinking about hammering a little Or should I just let my bumper alone on 7 bolts?
Old Jan 30, 2012 | 05:30 PM
defierro's Avatar
I cant even understand what I wrote! BOTTOM LINE, how do you tighten a bolt into a stripped nut!
Old Jan 30, 2012 | 05:32 PM
defierro's Avatar
Oh and it was the thread that stripped...
Old Jan 30, 2012 | 06:06 PM
D_engel's Avatar
You dont. You pull that bolt out, take it to ACE or somewhere else that sells grade 8 hardware, and you buy a replacement.
Old Jan 30, 2012 | 06:09 PM
suicideking's Avatar
x2
Take it out while you still can and replace it. Don't force stripped hardware in.
Old Jan 30, 2012 | 06:10 PM
OH9JK's Avatar
JK-Forum Ambassador
Are they bolts or studs?
If it is a bolt just replace it. If it is a stud you may need to chase the threads with a die and get a new nut.
If the nut is captured inside the bumper then you need a new bolt and a tap to chase the threads on the nut.
Make sense?
Old Jan 30, 2012 | 06:27 PM
Tonka_yellow's Avatar
X3 get a new bolt
Old Jan 30, 2012 | 06:37 PM
defierro's Avatar
The bolt is fine. It's the nut inside the bumper whose thread stripped. It's welded on.
Old Jan 30, 2012 | 06:40 PM
flounder's Avatar
look up HELI COIL insert they prob have them at your hardware store if not you can order online.
Old Jan 30, 2012 | 06:48 PM
rinkishJK's Avatar
The nut is prob only tacked on.. I would try to use a chisel or air hammer with chisel bit and knock that bad nut off and replace it with another. U could try a thread restorer, or a tap to fix it, but if it's really gone best bet is try and replace it. Helicoil won't really work on a nut. It's more for threaded holes in say an engine block...
