How to fix this?
Old Jan 27, 2011 | 05:19 PM
betjeep09's Avatar
Exclamation How to fix this?
2008 JK X
3" lift
33" tires
50K
20K with Mods
K&N Intake
Skyjacker Steering Damper
Other wise stock
Thinking about Magnaflow Dual Exaust
Old Jan 27, 2011 | 05:21 PM
nthinuf's Avatar
A new 'stock' driveshaft, or an aftermarket driveshaft with a set of adjustable control arms.
Old Jan 27, 2011 | 05:22 PM
wayoflife's Avatar
JK-Forum Founder
is it safe to assume that your drive shaft is spitting grease from the cv boot? if so, you need to replace it with an aftermarket u-joint style one.
rinkishJK's Avatar
The fix is a new double cardon style Driveshaft with new yolks.
sent by rinkish with a phone.
Old Jan 27, 2011 | 05:24 PM
betjeep09's Avatar
Question
Do I just remove the bolts around the seal and pull it down? Can I just replace the seal? Do I need special seal tools?
Old Jan 27, 2011 | 05:26 PM
wayoflife's Avatar
JK-Forum Founder
you cannot replace just the seal, you would need to replace the whole drive shaft and they aren't cheap.
nthinuf's Avatar
The joint on your driveshaft failed. It is not serviceable, and needs to be replaced before it loses all the grease and seizes.
Old Jan 27, 2011 | 05:34 PM
betjeep09's Avatar
Question
Write up on a replace thread?
Old Jan 27, 2011 | 05:40 PM
nthinuf's Avatar
Depends on which type you get. Factory or aftermarket 'factory replacement', it's just bolts. Simple swap. If you get one with new flanges, there is a writeup in the writeups area. (there is an index stickied to the top of the area)
Old Jan 27, 2011 | 05:42 PM
wayoflife's Avatar
JK-Forum Founder
this is for a front shaft but, it's more or less the same for the rear.
http://project-jk.com/jeep-jk-write-...ation-write-up
