How to get better street performance
I have a 14 JKUR. The relevant mods are 3.5 RK X-Factor lift with steering kit, 37” Nitto Trail Grapplers, 5.13 grears and a Fox steering stabilizer. In the 2.5 years I’ve owned it I’ve gotten out on the trails 3 time. Based on my current situation it could be even less frequent. My problem it’s way more trail ready than I need. Way less street ready than I’m comfortable with. I know my question is the opposite of what’s normally asked. I love my jeep don’t want to give it up but how do I make it more comfortable on the road. To be honest my son has a stock JK Willys and I don’t think that it’s any better them mine. In fact if anything it handles worse. What would everyone suggest to make it more comfortable and track better at higher speeds. I would still like to take it off road but it doesn’t even need to be as capable as a stock JKUR.
I’m assuming smaller tires but how small and brand/type. Should I just lower the suspension with new springs and keep everything else. Or should I just go get a Ram 4x4. Any suggestions would be appreciated. |
1 Attachment(s)
Steersmarts drag link and Griffin ... Trust me.
Also posting your current steering alignment specs would be pretty useful as well and outlining what you've done for caster correction after lifting if you've done any or not.
Understanding your point of reference for ride quality might be helpful as well. What are you comparing the ride quality to? After all, it is a Jeep with solid axles so there are some limitations on what can be expected from those solid axles. |
Go back to 35's and 2.5"- it's still off-road friendly and a great daily driver. Big tires look good but the extra wear they put on everything and replacement cost is tough to swallow if they're not being used.
You should easily be able to find a young gun that's hot and heavy for a big jeep. Trade tires, coils, and a couple bucks then you can both be happy campers. |
Honestly if it is on the table, go check out an air suspension Ram 1500. Either the rebel package or one of the higher packages will have it. They run great on the street and still return respectable fuel economy with the 5.7L.
For tracking, you could try increasing your air pressure. Switching to a more road oriented tire wouldn't hurt either. The BFG KO2 does have a 37" size (apparently sizes close to 35" tires from Nitto and Toyo) and there are other new hybrid ATs like the Grabber x3 and the new Nitto Ridge Grappler that would definitely help out with the tracking issue. Bracing your steering with the Synergy sector shaft brace and track bar brace with help out a lot. You should probably have done a drag link flip at that ride height as well. |
Originally Posted by Rednroll
(Post 4274065)
Ride
Sounds like you have totally the wrong build... or the wrong Jeep. Maybe re-thinking all that was done for a re-do, or selling it as is will rectify the situation. Most of us do not have an issue with the ride and handling. Part of understanding a Wrangler
Originally Posted by angrysea
(Post 4274069)
I did have it aligned*but that was*over 2 years ago. I'll have to dig up the print out.
(Post 4274059)
I’m assuming smaller tires but how small and brand/type. Should I just lower the suspension with new springs and keep everything else. Or should I just go get a Ram 4x4. Any suggestions would be appreciated. As much as I'd like to think mine handles better than stock on the pavement, it almost certainly doesn't because the C of G is 2+ inches higher, it weighs more, etc. It's kind of refreshing that the "placebo effect" isn't strong with you either. Anyway, If it were me I'd think about getting the lift down to 2" (or less), stock bump-stops, and a slightly longer shock like the OME. And since it has 5.13 gears -- Use the lightest 35" tires with an A/T tread pattern, flat fenders, and wheels with the nearest to stock offset possible. And I think the stock track-bar flexes enough to notice better handling with a stiffer one like the Terraflex version. But before anything, I'd inspect the hell out of it and look for anything out-of-spec loose in ball joints, steering links, track bar and brackets, etc. TheDirtMan has a writeup on lifts that is worth searching for, and there's writeups and videos on JK suspension and steering checks (often aimed at curing death wobble). :beer: |
A 35" AT tire and drop the lift down to the 2" range would gain you both performance and handling. At highway you would be turing some high Rpm's with 5.13 gears though.
Without actually seeing how your jeep is set up it makes it tough to look for any issues you may have. |
