How To Get The Most Flex???
Old Sep 25, 2012 | 07:44 PM
inspect-a-home's Avatar
Originally Posted by 2012-JKU-Brad
More down travel is the goal. If that's even possible.
Yes, very possible. Did not see anyone mention shock relocation brackets or EVO rockstar skids. Or shocks with shorter bodies and longer travel. or spring coil retaining clips. longer sway links. in the end you want to go with coilovers, 3-4 suspension systems later thats where I ended up.
Old Sep 26, 2012 | 02:48 PM
remingtonJK's Avatar
Originally Posted by BigSteve
I'll see your button and raise you an AntiRock. Ha checkmate!
I agree. Antirock is the only way to go!!
Old Sep 27, 2012 | 03:10 PM
LOST's Avatar
Just need longer shocks, discos, and brake lines to stretch those legs.
Old Sep 27, 2012 | 09:36 PM
dahreno's Avatar
Default flex
. I think I get pretty good flex , but I think it's up to you to ask the right people to get the right answers!
Old Sep 27, 2012 | 09:42 PM
dahreno's Avatar
Default flex
Old Sep 29, 2012 | 11:13 AM
DeucesALLin's Avatar
Evo rockstars, ext brakelines, longer rear endlinks and shocks.
Rockjock? Button? Guess I'm trump tight- swaybar deleated. F
Old Sep 29, 2012 | 01:20 PM
ralphwiens's Avatar
I was also trying to mazimize my travel for my Teraflex Performance leveling kit. Currie sells a max travel levling kit that basically adds bumpstops, spring retainers, and extended brake lines, and also recomend long travel RS9000XL shocks. I had asked opinions on doing this since I was only planning on going 33's, but got no response. I havent ordered my shocks yet, so havent decided to go that route or go with standard shocks for my Leveling Kit.
Im about to buy the 2.5in Tera Flex spring lift w/ bilten 5100 to match. I dont want to get any taller of a lift but I would like to maximize the flex I can get out of the 2.5in's.
so the question is, how to get more flex?
Should I get different sway bar links? Bump-stops? Adjustable control arms? Etc?
Any suggestions would be helpful.
Old Sep 29, 2012 | 07:43 PM
ryanralston07's Avatar
Specs on this rig? Great flex
Sent from my iPhone learning something new everyday!
Old Sep 29, 2012 | 08:02 PM
dahreno's Avatar
Default flex
The black JKUR has a 6" Pro Comp long arm with Fox remote resevoirs , f & r Rancho diff. covers and lower control arm skids , motor , tranny , and gas tank skids , as you can see a Teraflex front bumper w/ Warn 9000 ti winch , Hanson rear bumper w/ tire carrier 35 x 12.50 Pro Comp Xtremes on Pro Comp rims. It is not totally flexed out in this picture of it on the stairs. The stairs are in Gorman in the offroad training area if anyone want to go there and see how tall it really is , you may be surprised! By the way , here is a pic. of my other jeep. It is 51 years old , and will be around alot longer than any JK !
Old Sep 29, 2012 | 08:08 PM
dahreno's Avatar
Default no flex
0 flex from my rig!
