How hard is it to install....
2 bolts. Remove, put the new arm in, replace bolts. Do the other side. If you have it jacked up, wait until it's on the ground to tighten the bolts.
Check the Adjusting Caster section of the alignement write-up for some tips on lining up the bolts.
http://project-jk.com/jeep-jk-write-...-end-alignment
There is also a Teraflex 4" install write-up with the step by steps for their arms... (steps 12-14)
https://www.jk-forum.com/forums/show...7&postcount=10
you will be happy with those arms. They are built tough as nails and look nice as well. The increased caster really makes a huge difference in the way it drives. They are well worth the install effort and cost.
