how long will it take me to install a bb lift?
If i do it by myself how long do you think it will take?
I bouhgt a rubicon express 2" budget boost lift with their mono tube shocks.
its my daily driver so can i do the whole thing 4-8 hours on a saturday?
will i need to do a alignment afterwards?
thanks
thanks
You should not have any problems installing it in a day. The recommended time is 2-4 hours. Its not that hard to do. The first one will take you a little bit but after you get it down the others go quickly. With a 2" BB a alignment is not required just recenter the steering wheel. There is a good thread on here to do that with pics and it is super easy.
http://project-jk.com/jeep-jk-write-...ation-write-up
I know this is for a Tera kit, but its basically the same. RE kit doesn't provide sway links though
Save your money.
http://project-jk.com/jeep-jk-write-...-end-alignment
More than likely, the Toe will not need to be adjusted, and you can re-center the steering wheel in 5 minutes. Nothing else is adjustable without adding more components.
But, if you wheel, at full flex, the link could flip over and make dammage.
The stock links are too short for a lift (about5.5")
You have to buy, adj. sway bar link, or adj. quick disconnect.
TIP: buy used OEM rear links. (about 9") just perfect to install on the front
Allow your self 4 hrs. Includes a lunch break and a beer....
And made darned sure you tighten the track bars properly ie. Tighten the piss out of them. They do have a tourqe value but I forget what it is 150lbs???
I have the same lift right now. Took me and a buddy about 6 hours but we were not working the entire time. There is no alignment needed but you will have to adjust the drag link to re center your steering wheel and I recommend heading to the dealership and hooking up the star scan and adjusting your tire size to set the speedo. If you are running 33's it will be off 2mph after adjusting to the largest tire size the dealership has on the star scan.
