How many Lbs "O" TORQUE
Old Apr 4, 2007 | 05:47 PM
Jangle's Avatar
Default How many Lbs "O" TORQUE
Hey ya'll how many pounds of torque to tighten the lower control arm bolts??? I am installing the full traction premium on friday and can't find anywhere how much that bolt(s) take.
Thanks,
Jangle
Old Apr 4, 2007 | 06:21 PM
pulman01's Avatar
its 125 ft. lbs
One of our fellow members has a great site with lot of good info. You should check it out.
http://www.wanderingtrail.com
Old Apr 4, 2007 | 08:49 PM
mmccurdy's Avatar
I installed an Ultimate kit last weekend. Here are all the relevant torques I think you should need (all in ft-lbs, "while loaded" means when the vehicle is sitting on its tires):
FRONT:
upper control arms
upper bracket: 75
lower bracket: 75
lower control arms
upper bracket: 125
lower bracket: 125
shocks
upper mount: 20
lower mount: 56
sway bar link
upper bolt: 75
lower bolt: 75 (while loaded)
track bar
upper: 125 (while loaded)
lower: 125 (while loaded)
REAR:
upper control arms
upper bracket: 125 (while loaded)
lower bracket: 75
lower control arms
upper bracket: 125
lower bracket: 125 (while loaded)
shocks
upper mount: 37
lower mount: 56 (while loaded)
sway bar link
upper bolt: 75
track bar
