how many PSI you running?
Old Dec 7, 2007 | 08:41 PM
yellowjeeper85's Avatar
Default how many PSI you running?
So, i'm running 4 3/4" lift up front and 4" in the rear... i'm getting a wobble and still trying to narrow it down but i think its the tires. Juiced em up from 37 pounds to 42 and its a lot better but not perfect. So how many PSI is everyone with lifts and tires running. Oh by the way, they are a 35x12.50x17 Dick Cepek Mud Country
thanks,
Mike
Old Dec 7, 2007 | 08:45 PM
bump to the top since as soon as i posted this it was already bumped down by another post... anyway just posting to make it show up on the main page again, i would really like some input
Old Dec 7, 2007 | 08:48 PM
CLACKEY(_!_)'s Avatar
26 psi.......
Old Dec 7, 2007 | 08:56 PM
Originally Posted by CLACKEY(_!_)
26 psi.......
damn, 26 seems really low. Stock it called for 37... how do you like it at 26 pounds
Old Dec 7, 2007 | 09:15 PM
dang this thread is losing steam fast... and i'm trying to reach 500 posts... maybe my status will change anyway, i would like some input from everyone
Old Dec 7, 2007 | 09:21 PM
No really 26. I did a chalk test and at about 26 I get a nice flat footptint and a soft ride. My tires are wearng even. I should add I commut 150 miles a day in my JK. If you do a search you will find that this thread has ben done several times. That is most likely why you are not getting responses.
Hope this helps.
Old Dec 7, 2007 | 09:32 PM
dpoelstra's Avatar
your problem is most likely balance and not air pressure. I am running 33 inch BFG mudders and run at 32 psi, and that is pretty hard. I run them that high just so I don't wear the outside of the tread too bad on cornering.
I had a wobble when mine were new and had a good shop with the good latest computer balancer re-balance. Now they run smooth as a baby's bottom and are still pretty quiet.
Also, as a side note, with 33 inch tires and 17 inch rims, if I air down below about 12 psi I get dirt in the bead and have air leaks. I run 17 psi off road and get decent flex and no bead leaks. I want to go to 35's and a big reason is so I can air down further for better traction off road. The 17 inch rims are killing me for airing down.
Old Dec 7, 2007 | 09:46 PM
Hmm. i tried doing search and couldn't find much info on this. as for balancing i've had the tires powder balanced for a permanent balance, my JK just hates me in the cold... it runs nice and strong, but wobbles, and the drivers door lock likes to stick unless i unlock it twice on the remote. its goofy in the cold
Old Dec 7, 2007 | 09:49 PM
so i guess my new question should be whether to keep the powder balance or go back to lead weight balancing...
Old Dec 7, 2007 | 10:00 PM
duffman's Avatar
I don't know but 42 psi in 35's would just about knock the fillings out of my teeth. I'm running 26 psi in my 34x12 maxxis bighorns and that is where I got the best footprint and ride. I'd forget about the powder, go with the lead weight and lower the pressure.
