How much did your front drop?
How much did your front drop when you added the winch and bumper? My total package is going to weigh about 190 lbs and I was wondering if I should get a spacer for the front springs. Thanks
My front end dropped 5/16" with the front bumper alone which is probably just under 100 lbs (Rugged Ridge XHD bumper with end caps). Once I add a winch I will probably add the 1/2" TeraFlex spacers up front.
Droped mine an inch or lightly more with Warn Rock crawler bumper and Costco baught Champion winch BUT i have the rear loaded with Warn rock crawler rear bumper and a 30x36 box full of tools and trail supplys so RubyDoo ride even.
When I get a winch I am adding the Full Traction HD coils. I will evaluate then and see if I should add a spacer too! I have a rake now with my current set up which is fine. I just dont want more of one.
I'm adding an ARB deluxe bull bar and powerplant winch. Does any one know how much that will sag my front end? I was told that spacers would fix the problem. is it difficult to install spacers amnd do you need any special tools like a spring compressor? Thanks.
You will need taller Jack Stands (the 6 ton ones are taller)
