How much difference does a re-gear make
Old May 5, 2013 | 05:08 AM
BulldogMJP's Avatar
Default How much difference does a re-gear make
I'm just over 100000 miles and thinking about re-gearing from 4:10 to 5:13. I have a 2007 auto with 4"lift and 35's. Does re-gearing make alot of difference in performance. I find the ride OK with 4:10 and od off. Would going 5:13 will give me a big performance increase, or at least a noticeable one. I'd hate to shell out the cash and only get a slight gain.
Old May 5, 2013 | 05:16 AM
Jk kris's Avatar
Are you driving it everyday ? 5:13 is a a lot for a dd. you'll have a ton of pulling power out the hole but highway driving you'll be turning some serious rpms
Old May 5, 2013 | 05:20 AM
tcdawg's Avatar
It will make a nice difference. Is it going to blow you away and make you think you have a new motor, no. But it's a nice difference. Also helps your crawl ratio in 4 lo
5.13 for an auto on 35's is perfect. If you are breaking out the check book for gears you would not want to go any higher(numerically lower). I ran 5.38's with 35's for a year before I got my 37's, no problem.
You will be under 2500 rpm's at 70. Helps keep it from downshifting as much.
See if anyone near you has a similar rig with 5.13's and drive it. That will help you out in making your decision.
Old May 5, 2013 | 05:22 AM
BulldogMJP's Avatar
Yeah it's a DD. But I read 5:13 is best for an auto. Would it accelerate better and give me ability to use od again.
Old May 5, 2013 | 05:24 AM
tcdawg's Avatar
Yes. I don't ever turn OD off...5.38's and 37's.
Old May 5, 2013 | 05:25 AM
tcdawg's Avatar
This should help as well
Old May 5, 2013 | 05:29 AM
BulldogMJP's Avatar
Thx guys. 5:13 here I come.
Old May 6, 2013 | 03:21 PM
DGriz's Avatar
Attachment 454379
Is this the most current chart? Heck, if this is right, I should be running 5.13 with my 33" tires.
Old May 6, 2013 | 03:38 PM
nthinuf's Avatar
3.8 4door auto. I had 5.13's and 35's. Replaced the 5.13's with 5.38's when I swapped in a front d44. 5.38 is the better ratio for me.
Yep, these 07-11 autos are undergeared (underpowered) from the factory.
Old May 6, 2013 | 03:39 PM
CerOf's Avatar
That is the chart. If it is a true 33" tall tire when mounted, 5.13 would be fantastic. Most 33" tires when mounted are going to measure more like a 32.
Sent from some string and a few tin cans.
