How to rotate rear axle along longitudinal axis?
I am trying to set the wheels on the rear axle in the center of the wheel wells. I want to do this by setting the rear upper & lower CA lengths. I was hoping to use a jack as the device for rotating the axle, much like is described in the write ups on this forum for setting caster on the front axles. On the front axles you can place the jack on the CA mounts, to get the axle to rotate, but on the rear the CA mounts are different and I can't see how you can safely place a jack on the rear CA mounts.
My question is at what points do you jack the rear axle at to get it to rotate clockwise or counterclockwise. :dontknow2: Or better yet, how do you locate the rear wheels in the center of the rear wheels well? |
i used the floor jack underneath the pinion on the housing and lifted slowly into position, so that the pinion angles up towards the transfer case. not sure if that's what your hoping to accomplish.
Originally Posted by Monty-
(Post 1448214)
So the jack was secure enuf at the pinion to allow you to lift the axle without the jack slipping? |
i had the axle on jackstands and then just used the floor jack underneath the pinion. i had no trouble with this method but i only had adj upper arms to install.
(Post 1448228)
Originally Posted by JeepyJeep
(Post 1448231)
:thumbsup: Thanks.
You can also keep the frame supported by the jackstands, put your floor jack under the diff and then use the Jeep's jack to manipulate the pinion. Takes a little more time, but it's a safer way of doing it.
I used jack stands under the frame, a floor jack under the differential and hydraulic jack on the pinion. The jack on the pinion doesn't end up having to much load on it. Makes is possible to get your angle right on.
Originally Posted by seer1
(Post 1448297)
Originally Posted by madmax2
(Post 1448464)
Thanks guys. |
