How tall is a JK with 3" and on 35s
Old Jun 15, 2007 | 11:58 AM
Blue Meany's Avatar
Default How tall is a JK with 3" and on 35s
I am thinking of lifting my JK with a FT 3" ultimate lift and 35s, but I'm not sure if it'll make it through the garage door. Can some one please measure their similarly setup rig adn let me know the height?
Thanks for the help
Old Jun 15, 2007 | 12:03 PM
bcperry2000's Avatar
i just had my 3" black diamond kit and 35s installed. i'll probably measure tonight so i'll have to get back to you.
Old Jun 15, 2007 | 01:00 PM
Blue Meany's Avatar
thanks man.
Old Jun 15, 2007 | 01:09 PM
JKMAN's Avatar
Due to suspension and set up, every JK will be slightly different...
I would suggest you add 4.5" to your current height and that will net you new height. 3" lift plus 1.5" for the 3" difference in tire size if you have the stock 32" Rubicon or Sahara tires. This is what I did and worked out perfect...
Old Jun 15, 2007 | 02:06 PM
BigJerm's Avatar
i have 2.5" coil spacer with 35" tires and im the same height as my jeep and im 6'6"
Old Jun 17, 2007 | 11:11 AM
Blue Meany's Avatar
any one ever measure their rig?
Old Jun 17, 2007 | 11:38 AM
usmcdoc14's Avatar
yes, but I keep measuring from the base of the driveway and it always add a few extra feet
Hold on a sec, I will walk outside with a tape measure.
Old Jun 17, 2007 | 11:43 AM
usmcdoc14's Avatar
6' 7" at the highest point on the soft top with a 4" Superlift lift and 35" Radial Claws
Old Jun 17, 2007 | 06:24 PM
BigJerm's Avatar
that sounds right to me. If my set up is almost my size at 6'6" then his right on
Old Jun 17, 2007 | 06:48 PM
Blue Meany's Avatar
Thanks Doc and Jerm, I guess it'll fit in the garage no probs, so I'm gettin to orderin in the morning.
