The how tall is your rig thread
Old May 8, 2009 | 07:51 AM
Doc_D's Avatar
Default The how tall is your rig thread
I'm getting ready to do a Teraflex 3" lift on my 2 door. I had figured out it should fit in my garage. But then I found out people are getting 5" of lift from this lift on a 2 door . So I was going to ask someone to measure how tall their rig w/ a teraflex 3" is so I could see if it's going to fit in the garage. But then I figured I might as well keep it generic to help others out who are trying to figure out how tall their jeeps will be.
So if you've got nothing better to do, go out and measure to the hightest point on your roof and then reply and cut and paste in the following info.
Model (2 door or 4 door):
Top (soft or hard):
Lift make and size:
Tire make and size:
Aftermarket bumpers (Y/N):
Height:
Thanks many prospective lifters will be eternally grateful.
Old May 8, 2009 | 10:47 AM
Michigan Mike's Avatar
OK I'll bite!
2 door
soft top
Full Traction 3" Ultimate (really around 4.25")
35 " Toyo OC M/T's (actually 34.8")
Mopar Offroad front & rear (Warn XP9000i in front)
From the "bow" cross bar under the soft top (not the extreme back)....
79" bar top to the garage floor
Old May 8, 2009 | 11:20 AM
JPTwinz's Avatar
A thread with similar content was started last April and has about 7 pages of responses so far. This measurement was to the bottom of the fender line (we all have almost the same measurement from that point to the roof)...https://www.jk-forum.com/forums/jk-show-tell-33/show-your-measurements-35218/
BTW, mine measured to the bottom of the fender 53" front and 52 3/4 rear
Old May 8, 2009 | 11:33 AM
capt scotty's Avatar
Sahara 2 door Tera Flex 4" lift and 35 Toyos
Front 44"
Rear 42 1/2 "
To the bottom edge of the fender
Old May 8, 2009 | 12:01 PM
Doc_D's original question was to determine if a lifted rig would fit in his garage.
Using the "to the bottom of the fender" measurement mine's 42" front/42.25" rear.
Old May 8, 2009 | 12:30 PM
jkkat's Avatar
