"Hybrid" Lift
Old 07-24-2014, 10:34 AM
Stubicon's Avatar
This is the reply I received from Teraflex regarding the spring leveling kit. I have a '14 JKUR so take that into consideration. But may help your opinion.
"Hi Stuart. Our spring leveling kit on a Rubicon will provide about an inch of lift in the front and ¼”to a ½” in the rear. The Rubicon comes with a taller spring than a standard model jeep. You will still get the leveling effect from our lift. Our springs are a slightly higher spring rate than a stock spring. Our spring provide a smooth ride while removing the mushy feeling from a stock spring. You can retain your stock shocks and tires and rims with no need for wheel spacers. The extended sway bar links we provide will work fine with the elec. Disco. This is an effective way to gain a mild lift improve handling, but still maintaining close to stock suspension geometry.
Thanks for your interest,
Doug."
Old 07-24-2014, 11:00 AM
kjeeper10's Avatar
I've seen that ^
What's with "the rubicon comes with a taller spring"
That is definitely not true. The only model rubicon with a taller coil is the 10a
2007 Rubicon /2 door/6 speed
Old 07-24-2014, 11:43 AM
Stubicon's Avatar
Originally Posted by kjeeper10
I've seen that ^ What's with "the rubicon comes with a taller spring" That is definitely not true. The only model rubicon with a taller coil is the 10a 2007 Rubicon /2 door/6 speed
That's what I thought too. I have the regular Rubicon. Not the 10a. That being said, I figured I'd see a little more from the spring level kit.
Old 07-25-2014, 01:29 AM
kjeeper10's Avatar
The spring debate has been going on for years. 4 doors are more then likely to have the higher rated/taller coils. My 2 door Rubicon (w/ hardtop) had 15 front and 54 rear I believe. I've never seen a stock jeep with the 19/60 people buy direct from Mopar.
Old 07-25-2014, 04:14 AM
Stubicon's Avatar
This is what came off the springs on my JKUR. Click image for larger version
ID:	567446 Green is Front Orange is Rear
I also have the max tow package.
Old 07-25-2014, 08:05 AM
kjeeper10's Avatar
You have higher rated coils.
Quick Reply: "Hybrid" Lift
