Hydraulic Bump Stops Compared to Standard
Benefit of running hydro bump stops for trails, rock crawling, back roads, etc? I understand the concept of them dampening axle slap during high speed applications but seems tons of folks are using them on basic trail rigs.
I like the fact they are adjustable and look trick but what's the real world expectation?
I have hydro bump stops but have very little experience with them. I’m only using them since the Jeep came with the crappy teraflex foam can bumps and the mount for rubber bumps were cut during the teraflex bumps install.
However, I do like that the bumps cushion the Jeep when coming off of a rock that’s more than a foot tall. I cannot comment on other factors since I have very little use of them to this point.
I have been in rigs with them installed and running down the trail is a lot nicer if you happen to hit a big hole in the road or rock that you did not see. Where the stock bump stops still work you feel and hear the bang of the hit on the axels, these will not do that, they give so it is a smoother release of the impact, and as @SV_Dude stated, they do make a difference coming off the bigger rocks.
I have only wheeled a few trails in GA myself and do not remember any really big rocks, more hills, and red mud ,) but if you are getting the "Big Bang" when bottoming out, make the change, it will make your back feel just a little bit better after that big hit.
