Hydro assist help
Old May 20, 2018 | 03:14 PM
Jkbroc's Avatar
Default Hydro assist help
A little over a month ago I installed a tapped box and a PSC 1.75" x 8" ram. Bleed the system and everything seemed smooth. Went on a wheeling trip and worked like a champ minus my clamp sliding a bit.
About week or so ago I began to notice that when I turn it has a groaning sound when steering. It's still steering fine but it's pretty loud. Any advise on what to check? It really sounds
Like it's coming from the box but I can't pin point it. Is it possible there is air in the box and if so is there a way to bleed the box?
Definitely open to suggestions and opinions
Old May 20, 2018 | 07:29 PM
BoraBora's Avatar
Stock pump? Sound is probably coming from the pump. Didn't see anything regarding a cooler, so I must ask...did you install a cooler? If not, you should.
Old May 21, 2018 | 04:28 AM
jedg's Avatar
Vet Army
What BoraBora said... definitely recommend a cooler and take a look at your pump.
Old May 24, 2018 | 03:54 AM
SoK66's Avatar
Add a cooler.
