Hydro Assist (WTO) Steering Feel & Return to Center
Old 11-07-2016, 04:44 AM
  #21
jedg's Avatar
Originally Posted by Chuck-The-Ripper
I would assume a fair amount of people with hydro have a tuner for tire and gear ratio correction, if so you can turn your idle up. I have mine set at 1000 and it drives much better, I works assume it souls help with the increased flow needed for the larger ram.
I've thought about doing this ( I idle at 600rpm ) but it really only presents itself on the rare instance I want to park in a very tight parking spot where I lock right or left and then have to straighten out without moving very much. I don't see this symptom when crawling as I'm in 4LO and so the rpms are already higher at a given throttle pedal position.
Old 11-07-2016, 02:10 PM
  #22
T&ERun's Avatar
Originally Posted by TweakJK
On the poor steering at idle topic, mine was terrible, but I run a 1.75x8" ram which is larger than most.
A PSC pump cleared that right up.
The stock pump does OK with smaller rams.
X2 for me too. No problems for a year on 40s with a stock (WTO rebuilt) gear and the PSC pump and reservoir.
Old 11-08-2016, 01:09 PM
  #23
TweakJK's Avatar
I was unaware that you could do this. My tuner (hypertech) wont do this. I imagine it wouldnt work well with an auto.
Quick Reply: Hydro Assist (WTO) Steering Feel & Return to Center
