A Hypothesis on Backspacing (No, This Isn't What You Think)...
A hypothetical...
The consensus for appropriate backspacing on aftermarket wheels, on here, is 4.5". Stock is 6.25", IIRC. Do we automatically assume the preferred 4.5" backspacing is for a 9" wide wheel or are you guys keen to the same backspacing on anything from 8" wide to 10" wide? The reason why I ask is... well... below, beware of the thought process:
When looking at the wheel itself, you want it to be as balanced as possible. Perfect measurable balance occurs when the backspace equals one-half of the overall wheel width. So, for a 8.5" wide wheel (I am intentionally not choosing a 9" wide wheel for the sake of this hypothesis)... the median backspace would be 4.25". Given that more material (the face of the wheel, where the hub mounts) would be at the front of the wheel... a 4.25" backspace on a 8.5" wheel would place extra weight (not necessarily nominal given the weight of the typical wheel) on the front of the wheel. This, of course, would transfer to the hub... and then axle. Wouldn't you want to offset this by cheating to the backside of the wheel, i.e. On an 8.5" wide wheel, choosing a 4" backspace or maybe a 3.75" backspace. This theory is personified when you consider a 4.5" backspace on a 10" wide wheel... as the load (extra weight) shifts to the backside of the wheel.
I am not entirely retarded and understand the elements involved, I also understand the premise of wheel balancing and weights. I'm just thinking about how to mitigate the use of weights and how to place as little extra weight/load on the hub/axle. In the end, it really seems marginal and not really worth the energy I have put into thinking about this (and typing this thread), but, needless to say, I'm flexing my brain this morning. :brain flare:
I'd draw a picture to help explain this, but I suck at drawing. My forte is words... so hopefully I explained this hypothesis thoroughly (enough). So, if I missed something in my drivel, above, ask away.
Best,
JB
Best,
JB
There may be merit to your thinking on pavement but offroad you don't know where the load is going to be applied across the tread of the tire. In fact, it will probably wander across the tread as the terrain changes.
The main criteria for choosing backspacing is to make it so the tire doesn't rub the vehicle. The components are designed to handle the load offsets. Otherwise, the designers would have followed your suggestion when closing the back spacing on the factory wheels. They could have easily centered the hub and made up the distance in axle length.
As for eliminating rubbing and, also, the associated aesthetics, I grasp that. Again, just thinking out loud and waxing poetic.
Perfectly centered wheels will, of course, rub if much wider than stock. So you have to have them project beyond the end of the axel to avoid this. I am curious about how the Jeep axle and bearings handle this additional stress (torque). Does the Jeep have unit bearings (I hear they wear out quickly if wheel is not centered), or the old-fashioned (and maybe more rugged) hub bearings?
With the potential additional weight of the wheel and a larger tire, considering weight distribution on the hub/axle has an advantage. I imagine, again, that it's minimal, but I still want to talk it out.
You are over-thinking it. The length of the lever/vector is too small to make a difference comparing 6.25" to even 3" backspaced wheels.
Most new cars and trucks that have high marks for handling have backspacing that exceeds 1/2 the wheel width.
The unit-bearing/hub of the JKs are fairly strong and rarely fail--which is surprising given what we run on them.
As disclosure, I had one go out at around 7k miles after running 35s on 17x8, 4.5" backspaced wheels. Since then, I have run 37s on 4" backspaced 15x8s, 37s on 4.5" backpaced 17x8s, and 40s on 3" backspaced 17x8.5s, with no failures.
The TJ unit-bearing/hubs were weak. The JK version is strong.
In the end, what backpacing does for us with JKs, is it allows us to turn with a given degree of sharpness (radius) before the tires rub on the frame, front lower control arms, and/or swaybar. The larger the tire, the more we need less backspacing to be able to turn sharply. You could run 40" tires on 4.75" backspaced wheels, but your turning radius would be worse than a 1 ton dually longbed crew cab truck.
You don't need to baby the JK unit-bearing/hub.
Your comments include a level of detail and analysis that makes my pants tight.I know I am over-thinking it, my contention was more an exercise of theory and less about an actual application. That being said, my intended setup is 315-70/17 on 4.25" backspaced 17" x 8.5" and I am not particularly worried about the setup or my hypothesis/theory in the original post. It's Friday and I felt like exercising the old noggin.
Thanks.
