I got some really bad advice here...
Old Apr 22, 2014 | 06:21 PM
  #101
jeepmojo's Avatar
Default How could you have not noticed the uneven wear to this point???
and then blame the forum on bad advise ? any fool looks at their tires just walking back from walmart ( its obvious your own negligence ) to rotate a tire you don't need to have a job even . pure neglect . I can see not being able to fund new tires but if they were as you claim take offs and little wear on them , you would have to be nearly blind not to see they were wearing abnormal .Click image for larger version
but to blame the forum for crappy advise is just lame .
maybe good advise would be to get your vision checked
  #102
jaker t5's Avatar
Originally Posted by ShiftKnowledge
I spoke to a Jeep salesman, and he assured me that its now different.
Ok , I guess car salesmen know more about jeeps then the guys working and building them
With that said I am going to pull the offer off the table to help you with your suspension you can take it to a dealer they know more
Old Apr 22, 2014 | 06:31 PM
  #103
Ruby Tuesday's Avatar
I can't believe you guys are still trying to reason with this troll.
Old Apr 22, 2014 | 06:33 PM
  #104
Sahara Lee's Avatar
What in God's green acres makes you think you can believe ANYTHING a car (or even Jeep) salesman tells you?
Old Apr 22, 2014 | 06:35 PM
  #105
jeepmojo's Avatar
Default i know its
ridiculous
Old Apr 22, 2014 | 06:40 PM
  #106
JKSLEEPR's Avatar
x3 I'm done . . .
Old Apr 22, 2014 | 06:46 PM
  #107
Grubbicon's Avatar
to be honest i dont think hes a troll i really dont thunk he knows
Old Apr 22, 2014 | 07:27 PM
  #108
46chevytruck's Avatar
You should seriously look into the t-Rex short arm lowering kit and then install those rims and tires I mentioned earlier. Some paint on your brake calipers may also help with heat redistribution lowering friction in the front sway bar redistribution center allowing for the tires to float across the road vs rubbing like sand paper on hot balsa wood. The t-Rex short arm kit fixes the factory geometry and allows for the use of bags or hydraulics if you want to go that route. Just a few thoughts to consider. Check out TonyGmoney on the forum for additional details.
Old Apr 22, 2014 | 07:31 PM
  #109
Angry_Fisherman's Avatar
Originally Posted by towel33
Whens the last time you had an alignment done? That's not your tire pressure. 30 is still possibly too high, you look bone stock.
Do you have a 2 door or a 4 door?
  #110
arjeeper's Avatar
Have you tried a throttle body spacer? I've heard it can help so much on Jeeps.
(Sorry man, I had to)
But really, get an alignment and buy some used street tires from a tire shop to get you by until you find a job.
