I have questions who has answers
As far as the sticker goes. Certain things are standard items like the soft top. When you upgrade to say the hard top then the soft top gets deleted. You have to choose the dual top to get both. Same goes for tires, etc. When you upgrade tires and rims the ones listed under standard options get deleted.
They can only void your warranty on items that may break due to your mods. Big tires for instance will probably void the warranty on your axles if they break.
Some areas may be gray and it will vary from dealer to dealer. Some dealers are a little more friendly to lifts than others. After all DC pays them to fix these items so they want your business.
Rubimon
So I should check with my local dealer before doin a lift.
What transfer case do you have with those 35s and what lift do you have. I have the same color x and it looks really good.
Thanks
Thanks
As far as asking your dealer, it may be okay, but they may want to do the lift and charge you a bunch to do it. Take what they say with a grain of salt and then pass the info back on to the forum for advice. You may get all types of answers from the dealership " It won't be warranted unless we do it, " etc. If you are mechanically inclined you and a friend or fellow jeeper could do it with the help of Eddie's write-ups on project-JK. The good part about doing it yourself is it helps you learn your Jeep and there is a level of satisfaction from doing it yourself.
Do a search on this forum for threads about voided warranties. It will help ease your mind on that.
Hope I was helpful!
I put BFG's on 285/70-17 on my stock Jeep wheels and I have a little rub on the front stabilizer, BFG's 32.8 tall, stock tires were 30.8. I will get some new rims to get the tire to stop the rubbing. Looking at the Cragar 342.
http://www.quadratec.com/sb/2007_Jee.../jk_wheels.htm
My Jeep dealer tells me if I do a lift kit on my on that they might not cover my warranty if something happens in that area. Wheels spacers to me is just something that can brake and I dont need that if I’m out have fun.
This is a handy page I found
http://www.1010tires.com/TireSizeCalculator.asp
Good Luck
Good Luck
