I have a Steering Stabilizer problem...Need solution!
Old Mar 2, 2012 | 03:47 PM
FlameRedJK's Avatar
Default I have a Steering Stabilizer problem...Need solution!
I bought the Rock Krawler HD Tie Rod for my 2012 JKU.......the factory Steering Stabilizer bracket on the Tie Rod wont fit on the RK Tie Rod because of the increased diameter.
Does anyone know the part number for the bracket that was used on years 07-09 or where to find the parts diagram? From what I have come to understand they changed it on 10-12 models.
Rock Krawler has made a bracket to solve this problem but when I called they said it was like 95 bucks....I'm hoping the factory bracket from the previous years will be cheaper than the RK bracket.
To be specific, its the bracket that attaches the steering stabilizer to the tie rod, not the end at the knuckle.
Dear, Rock Krawler.
I just gave you guys a couple thousand dollars.
Wanna give me a deal on a bracket?? ;o)
Old Mar 2, 2012 | 04:11 PM
JKZinger's Avatar
JKS makes a really good, beefy one!
Old Mar 2, 2012 | 04:18 PM
FlameRedJK's Avatar
Yes I've seen that...Not what I'm talking about though...I need the bracket that mounts the SS physically on the Tie Rod....The bracket that is held on by the two U-Bolts.
Old Mar 2, 2012 | 04:20 PM
FlameRedJK's Avatar
This is the Bracket on years 07-09 (someone correct me if im wrong)
This will work with the RK HD Tie Rod because they supply you with new larger U-Bolts.
This is the Bracket on my 2012 (sorry its a lil dirty...just the way it should be)
Aint no way in hell this is going on the RK HD Tie Rod.
