i,m going out on a limb here with JK code you can't explain
Old Apr 16, 2015 | 04:10 PM
mudlake1's Avatar
Default i,m going out on a limb here with JK code you can't explain
Last winter my 2014 thru code for cam,engine management and transmission and bus codes. Took it to the dealer who cleared the codes and charged me 112 dollars.Won't be back. They said its because i wired up a CB power feed. Bunch of A-holes. About a week after that it happened again codes all over place.
I have a MAC tool reader and i documented the codes and cleared them.
Did my own mechanic research under the hood and found the negative battery connector was loose when you wiggle the cable.
I think these battery cable are a way too cheap.
I have replace the battery cables with old style connectors from auto zone and have not had any codes since.
This is only my opinion. Maybe it will help remove some problems.
cheers
