I need some advice!
Old Nov 11, 2008 | 04:26 PM
DANiEL's Avatar
Default I need some advice!
Hi! I need some advice.
I want to modify my Rubicon with Fox Racing Piggy Back Reservoir shocks. Are these direct fit or they need adaptations and what are these? Does anyone have any pics?
To regear the differentials to 4.56, is it correct to order ( for Rubicon ): http://www.quadratec.com/products/52419_95X_B_PG.htm
http://www.quadratec.com/products/52419_95X_C_PG.htm?
Is it necessary to order the install kits for these?
Thank you all for your help!
Old Nov 11, 2008 | 06:33 PM
JackMac4's Avatar
Yes, those are the right gears - but don't forget to order the install kit: http://www.quadratec.com/products/52419_807.htm
There is an install kit for the front too. http://www.quadratec.com/products/pr...ears&c=54&pg=1
Also, why are you only going to 4.56? If you're going to regear I'd go at least 4.88, if not 5.13 depending on what tire size you'll run.
I have never run Fox shocks so I cannot answer that question.
