i want it to come with everything.
Old Jul 22, 2011 | 10:26 PM
DROELLE's Avatar
Default i want it to come with everything.
Im looking to upgrade my jeeps lift. Looking for a long arm lift. But I want it to come with everything. Shocks, soils, disconnects, drive shafts, brake lines the whole shebang! Any tips would be helpful thanks
Old Jul 22, 2011 | 10:30 PM
bastard431's Avatar
I just got the pro comp lift kit 4 inch it was $1,900 but came with the whole shabang, good luck bud
Old Jul 23, 2011 | 02:28 AM
Mark Doiron's Avatar
Originally Posted by DROELLE
... long arm lift. But I want it to come with everything ... Shocks, soils, disconnects, drive shafts, brake lines the whole shebang! ...
I don't think such a single kit exists--at least not with driveshafts and maybe with brake lines. Your best bet would be to contact one of the vendors (I recommend Northridge, but there are other goods ones around) and ask them to help you put together everything that you will need.
But, the challenge is there are some variables out there. For example, I have a 2.5" TF coil lift. You'd think that would be great, but because of my specific needs (run expedition style with lots of added weight from hardtop and rack and gear; or run for "summer fun" with little more than a safari top), my rear end has a range of about 0-1.5" of sag, depending on what I have installed and how much gear I have. I know there are things like the JKS ACOS, but I don't want that much additional lift because it then drives more cost (driveshafts, rear control arms, move rear axle spring perches, etc). Therefore, I'm replacing the rear springs with a set of OME HD 3" springs--to see what will happen and my next avenue for attacking my problem--if that doesn't satisfactorily solve it. You may or may not have a similar experience: It depends on where you take your build and it's unlikely that you'll ever find the perfect, complete kit.
Old Jul 23, 2011 | 10:38 AM
CerOf's Avatar
Trailmaster has a complete lift including shafts
Old Jul 23, 2011 | 10:45 AM
josh_jacklyn's Avatar
teraflex's long arm comes with everything... most any lift companys will supply everything you need for your long arm lifts, besides your driveline mods that they reccomend to be done.
Old Jul 23, 2011 | 11:16 AM
JayhawkJeep's Avatar
Veteran: Navy
What do you want in you lift? How high? Budget?
Old Jul 23, 2011 | 11:53 AM
ChryslerChris's Avatar
Or job your rig out to companies like American Expedition Vehicles (AEV). They basically put everything you need into one complete kit.
Old Jul 23, 2011 | 12:54 PM
DROELLE's Avatar
I want to be able to crawl over my wifes ford escape. The bigger the better. Cost uh I wouldn't go over 5 or 6.
Old Jul 23, 2011 | 12:55 PM
DROELLE's Avatar
Ill be checking them all out. Lol! Thanks keep'em comen!
Old Jul 23, 2011 | 01:02 PM
DROELLE's Avatar
My main goal is to run 39.5x15x15 TSL super scampers if that helps any. I under stand all the stress, and the strength that ill have to put into my axles. But that's being taken care of very shortly from now. I will also be buying 37's for when they are called for on certain offroading clubs, trails, or events.
