I'd like to run 37s or 40s advice?
Old Oct 12, 2015 | 05:12 PM
trailguy's Avatar
Default I'd like to run 37s or 40s advice?
Looking to run 37s or 40s on a 2 dr, any advice would be much appreciated please let me know lift size, tire size and gear ratio thanks
Old Oct 12, 2015 | 05:17 PM
davids2011jk's Avatar
there are so many threads on this site along with others, this question has been asked like over a million times lol search google or this site search feature should pull up about 1000000000 results
Old Oct 12, 2015 | 05:26 PM
trailguy's Avatar
10 4 thanks pal
Old Oct 12, 2015 | 05:37 PM
nthinuf's Avatar
Lots of variables. Start with the Thoughts on Lifts thread stuck right to the top of this modified area. Then search for any post by Planman. In the sig line you should find a link to a good build thread for a low cog route to 37's. He ended up on 40's, so you should find some good info.
Gearing will depend on engine and location and axles and whatever else. But you might plan on 5.38's.
What is your budget? What axles are you planning on? Full width d60's? 14b? How much work will you be doing yourself? Gear setup? Welding? Planning on flat flares, correct? Fill in as much of your build plan as you can to get better feedback.
Old Oct 12, 2015 | 06:03 PM
Biginboca's Avatar
I just googled "run 37's on JK" and tons of info came up. You can find out all you need to know with Google and the thoughts on lifts in this forum
