Ideal Tire Pressure for Freeway
I usually run my 35'' km2's @ 30 psi around town for comfort. What's the ideal pressure for freeway speeds in regard to getting the best tread life/ least heat generation? I was thinking 35-40? The max is listed as 50psi. Even 40 sounds high to me...what are your opinions?
I've been running the 35" Toyos at about 29 with freeway driving, more than that and I'd worry about uneven wear. I'd think you'd be good at 30 psi.
Getting a tread depth gauge, and using it regularly is a good suggestion.
I'm at 9K miles and mine have been shockingly even.
Sounds good. I kind of figured you'd want to run higher pressure to reduce temps, with hi temps being what would degrade tread faster. If you guys are all running ~30 though with even treadware I'll just stick with that.
