If i upgrade from 4" to 6.5"?
Old Jul 7, 2009 | 04:16 PM
welker-jk's Avatar
Default If i upgrade from 4" to 6.5"?
CURRENTLY IM RUNNING THE RC 4" LIFT ON MY 2DR. i WOULD LIKE TO GO TALLER AND THOUGHT ABOUT THE RC 2.5 COIL SPACER LIFT. I HAVE STOCK DRIVESHAFTS NOW BUT KNOW I NEED TO AT LEAST UPGRADE REAR DRIVE SHAFTS BUT WHAT ELSE. WILL MY SHOCKS THAT CAME WITH MY 4" LIFT BE GOOD WITH 6.5 OF LIFT? i SAW THAT THE RC 2.5 CSL COMES WITH SHOCK RELOCATION BRACKETS? WHAT DOES THAT MEAN? WILL I NEED TO USE THEM? REALLY WHAT I WANT TO KNOW IS HAVING RIGHT NOW A 4" LIFT AND PUTTING THESE COIL SPACERS ON WHAT WILL I NEED TO ADD OR CHANGE?
Old Jul 7, 2009 | 04:24 PM
Bustabizz's Avatar
Former Member
You will need the front shaft as well, it will rub on the skid plate. Any reason you want to go that high? The shock relocators are for using your factory shocks. So yes you would want to use them with the spacers to keep from needing new shocks.
Old Jul 7, 2009 | 04:30 PM
welker-jk's Avatar
so i would need to use the brackets with my rc shocks that i have on now with my 4" lift? To bad i need a front drive shaft also i would be looking at some serious cash for all that. No reason for the added height i dont really need more clerance but damn i love the high riders! It would just be for me so looks i gues i just like jacked up rides! If i need front and rear drive shafts plus i have a dana 30 in front so probably no bigger than 35 tires i guess i better not do it
