I'm back! Need some serious advice and second opinion.
Welcome back and welcome to the forum. There's a very informative sticky here that may help you with some of your questions:
https://www.jk-forum.com/forums/modi...-lifts-288269/
You'll hear a thousand opinions on lifts and here's mine!
I'd drive it around for awhile. The difference between this jeep and your old jeep in stock trim are light yrs apart. You may find for what you want to the stock JKUR is just fine.
Before going all out AEV check out the other lifts, Teraflex, Rock Krawler and so on. Bilstein 5100's are good shocks for on and off road and won't break the bank. Either teraflex 4" or rock krawler 3.5" with the bilsteins and 35" tires will give you an excellent ride on and off road. As for the rest of it, you will want to dig around on the sites, Rockhard, Poison Spyder and so on to figure out what appeals to you.
Some things you didn't mention...
You may want to give Jim at rockspyder4x4 a call. He is a serious jeep builder and builds custom rigs as well as mild ones. He'll know how to setup the jeep for you. I don't use Just Jeeps as they are a bolt-on shop and pretty much sell shitty pro-comp and rugged ridge components.
Hi Rob, thanks for the recommendations. Your the second person to mention the steering stabilizer, I will have to look into that as well. Thanks again
Former Vendor
Take a look around at some of the current jk builds, you don't need quite as much lift height for the tire sizes you are looking at. Our 2.5" kits will fit a 35 with factory flares just fine and if you add a flat fender you can put a 37 on that same lift height. This can keep drive line happier and won't require as much if any steering corrections.
RK
RK
RK
RK
Former Member
Go nuts with whatever but after a lift that was undrivable from Just j--ps on my rig a while back I ran right back in there with a WTF moment. The drivetrain vibration would shake your teeth out at 30kph. I knew as soon as I was on the 401 that the pinion angles to the the diffs were f'd cause they didn't install the bevelled shims that came with the kit. XJ with leaf springs.
Took it back and they sent the 'lead mechanic' out with me for a drive and as he's almost being chucked out the sunroof from the vibrations he says, and I quote, "oh this is normal for a Rubicon Express 2.5" lift".
Went to counter after drive and they stood behind the 'we got your coin and f'u' stance.
A week later I found a guy in Bowmanville with a towing yard and offroad shop (pm me for name) and after 2 attempts at the correct pinion angle fixed those other guys screw-up for free. What really blew my mind is they torch cut the new u-bolts to length so poorly that he replaced those for free too because they couldn't be loosened off for the shim install.
Guess who I do and Don't use now. Go ahead and follow the flock to the slaughter or look to the left and right.
Good day, "My immediate area" brother. I'm in Newmarket and picked up a 14 JKUR last year after trading in a stock 12 JKUR. I outfitted mine to do the very same fun that you described and it's my DD into Markham. Very happy with the outfit I chose. I took this one to Jim at Rock Spyder for my AEV lift, tires and rims. I wouldn't take it to anyone but Jim now. The service was absolutely unmatched. And we meet every summer Tuesday night in Aurora at the Tim's just to shoot the shit with a large group of Jeep wheelers. Some of the nicest folk I've ever met. Jim provides ongoing support for any questions or concerns I have. If you want to speak about my build, PM me and I'll give you my info to drop me a line. Welcome back!
Isn't this where the link to the Thoughts on Lifts thread comes in? They have a base kit with front/rear axle centering but no caster correction. Then a kit that adds caster correction. Then a kit with caster correction up front and pinion correction in back. And then... You need to come up with a budget and decide which components are important to you.
my preference would be to pass on the base kit because caster correction is kinda nice to have. Since you have a 4door, rear pinion shouldn't be a big deal. So if budget is an issue, go for the Flex system and slowly add components to make it a Max travel or X-Factor. If budget isn't a factor, go nuts.
Took it back and they sent the 'lead mechanic' out with me for a drive and as he's almost being chucked out the sunroof from the vibrations he says.....
Well it was an expensive day yesterday but I had some excellent advice from Aaron at 4 Wheel Parts in Burlington. It's nice to chat with someone who will tell you "I would love to sell you this expensive lift but all you need is X" I was there for a couple hours and sorted out my wheels and lift. I ended up going with the 2.5" Teraflex Lift Kit with fox shocks.
I dealt with 4 Wheel Parts in the past and they were great. 10 min away too so that's convenient or expensive... probably both.
Parts are on order and so is the Jeep but when it all comes in, I will post some pics.
Thanks again for all you help.
