I'm torn between?
I'm torn between buying the Rubicon Express 2" spacer system with twin tube shocks or the Teraflex 2.5" budget boost kit with adapters? I'm pretty new at lift kits and was wondering what is the best "bang" for my buck? Any help is appreciated!
Teraflex seems to be real popular on here.
I've heard alot of positive things about the Teraflex and also that their customer service is great. I have the Teraflex leveling kit and though there are not many parts I think the build quality is good.
With the Teraflex basic BB for $338, you get four spring spacers (all 2.5", no rake leveling), four bump stops, longer rear swaybar links (you can move your stock rear swaybar links to the front, they are longer), rear brake line brackets, four shock extensions, rear frame mounted track bar drop down bracket. Just the cost of this kit alone with all the extras seems more bang for your buck. If you add four shocks for $145, you are still under the cost of the RE BB, and have a lot more for your money. IMO
When I changed to an OME spring lift, I kept the bumpstops, brake line brackets, and longer swaybar links in the rear from the TF BB.
What size tire do you plan on running? Do you have a 2dr or 4dr?
